Ana içeriğe geç
Astro A40 Gen2 Mixamp Motherboard Replacement
Neye ihtiyacın var
  1. Astro A40 Gen2 Mixamp Motherboard Replacement, Remove Dials: adım 1, 3 resimden 1. Astro A40 Gen2 Mixamp Motherboard Replacement, Remove Dials: adım 1, 3 resimden 2. Astro A40 Gen2 Mixamp Motherboard Replacement, Remove Dials: adım 1, 3 resimden 3.
    • Remove the dials using either a metal spudger or your hands. Be careful as the dials may be difficult to remove.
  2. Astro A40 Gen2 Mixamp Motherboard Replacement, Remove nuts and washers.: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Locate the two 11/32 inch nuts underneath the dials.
    • Use an 11/32 inch socket wrench or tweezers to unscrew and remove the nuts and washers.
  3. Astro A40 Gen2 Mixamp Motherboard Replacement, Remove back pad.: adım 3, 2 resimden 1. Astro A40 Gen2 Mixamp Motherboard Replacement, Remove back pad.: adım 3, 2 resimden 2.
    • Using a larger metal spudger, remove the rubber back of the mixamp.
    • The back will have glue residue after removal. Depending on the stickiness of the residue, more glue may be needed to stick the backing back on.
  4. Astro A40 Gen2 Mixamp Motherboard Replacement, Take out main case screw.: adım 4, 1 resimden 1.
    • Remove the one 4.5 mm Phillips #0 screw on the back panel of the mixamp.
  5. Astro A40 Gen2 Mixamp Motherboard Replacement, Pry open the case.: adım 5, 3 resimden 1. Astro A40 Gen2 Mixamp Motherboard Replacement, Pry open the case.: adım 5, 3 resimden 2. Astro A40 Gen2 Mixamp Motherboard Replacement, Pry open the case.: adım 5, 3 resimden 3.
    • Using a large metal spudger, detach all plastic clips holding the bottom and top casings together.
    • Remove the input casing using your fingers.
    • Be careful when releasing the clips between the two casings, as it is very easy to scratch the mixamp or break the clips.
    • Use caution when pulling the two casings apart as it is very easy to pinch your fingers between them.
  6. Astro A40 Gen2 Mixamp Motherboard Replacement, Remove the motherboard from the case.: adım 6, 1 resimden 1.
    • Remove the four 5.8 mm Phillips #0 screws on the motherboard.
  7. Astro A40 Gen2 Mixamp Motherboard Replacement: adım 7, 2 resimden 1. Astro A40 Gen2 Mixamp Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the motherboard from the casing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mark
412 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-18, Maness Winter 2015 Cal Poly, Team 20-18, Maness Winter 2015 üyesi
CPSU-MANESS-W15S20G18
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Where would I find a motherboard? And would it save money fixing the mixamp?
benaiah paul - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 44
Her zaman: 8,819
