Ana içeriğe geç
Astro A40 Gen2 Speaker Replacement
Neye ihtiyacın var
  1. Astro A40 Gen2 Speaker Replacement, Ear Pad: adım 1, 2 resimden 1. Astro A40 Gen2 Speaker Replacement, Ear Pad: adım 1, 2 resimden 2.
    • Pull one corner of the pad to release it from the headset.
    • Pull the rest of the ear pad off.
  2. Astro A40 Gen2 Speaker Replacement, Speaker: adım 2, 2 resimden 1. Astro A40 Gen2 Speaker Replacement, Speaker: adım 2, 2 resimden 2.
    • Locate the four 4.5 mm Philips #0 screws on the panel shown.
    • Remove them using a Phillips #0 head screwdriver.
    • Remove the panel.
  3. Astro A40 Gen2 Speaker Replacement: adım 3, 2 resimden 1. Astro A40 Gen2 Speaker Replacement: adım 3, 2 resimden 2.
    • Using either your fingers or a plastic opening tool, pry off the speaker cover.
  4. Astro A40 Gen2 Speaker Replacement: adım 4, 1 resimden 1.
    • Locate the four 4.5 mm Philips #0 screws as shown on the speaker housing.
    • Remove the four screws using a Phillips #0 head screwdriver.
  5. Astro A40 Gen2 Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the housing to reveal the speaker.
    • Make sure not to break the small wire holding the two portions together.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Donavan Feliz
444 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-18, Maness Winter 2015 Cal Poly, Team 20-18, Maness Winter 2015 üyesi
CPSU-MANESS-W15S20G18
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Where do you buy the replacement speaker ? Thanks.
Steve Rosam - Yanıt
what speakers can these be replaced with? this guide is a little short on details about the actual removal and replacement of the speakers. the information here is just the start
Jasper W (Spike229) - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 4,436
