Ana içeriğe geç
Astro A40 TR Plus Mixamp M80 Headband Replacement
Neye ihtiyacın var
  1. Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: adım 1, 3 resimden 1. Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: adım 1, 3 resimden 2. Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: adım 1, 3 resimden 3.
    • Use a screwdriver with a H2.0 head to remove the two screws on the upper headband plate.
    • Use a screwdriver with a T9 bit to remove one screw from the upper headband plate.
    • Remove the upper headband plate.
    • Repeat the past three steps for the upper headband plate on the other side.
  2. Astro A40 TR Plus Mixamp M80 Headband Replacement: adım 2, 3 resimden 1. Astro A40 TR Plus Mixamp M80 Headband Replacement: adım 2, 3 resimden 2. Astro A40 TR Plus Mixamp M80 Headband Replacement: adım 2, 3 resimden 3.
    • Use a screwdriver with a H2.0 head to remove the two screws on the lower headband plate.
    • Use a screwdriver with a T9 bit to remove one screw from the lower headband plate.
    • Remove the lower headband plate.
    • Repeat the past three steps for the lower headband plate on the other side.
  3. Astro A40 TR Plus Mixamp M80 Headband Replacement: adım 3, 1 resimden 1.
    • Use your hand to remove the headband adjuster.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 37
Her zaman: 2,815
