Ana içeriğe geç
Giriş
The guide allows for you to take apart and replace the channel selection switch on an Astro A50 gaming headset with only a Phillips head screwdriver.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the foam ear padding by pulling it straight to you Remove the foam ear padding by pulling it straight to you
    • Remove the foam ear padding by pulling it straight to you
  2. Remove the four 3.5mm Phillips head screws circled in red, and remove the grey cover
    • Remove the four 3.5mm Phillips head screws circled in red, and remove the grey cover
  3. Remove the four 3.5mm Phillips head screws circled in red and remove the silver cover.
    • Remove the four 3.5mm Phillips head screws circled in red and remove the silver cover.
  4. Remove the motherboard remove the four 3.5mm long Phillips head screws circled in red. Remove the 3.5mm Phillips head screw circled in blue to remove secondary motherboard.
    • Remove the motherboard remove the four 3.5mm long Phillips head screws circled in red.
    • Remove the 3.5mm Phillips head screw circled in blue to remove secondary motherboard.
  5. Separate the secondary mother board from the motherboard by pulling firmly to the right on the white connector.
    • Separate the secondary mother board from the motherboard by pulling firmly to the right on the white connector.
Sonuç
William Czerwonka
201 İtibar
2 adet Kılavuz yazıldı
Takım
IUPUI, Team S1-G1, Baechle Fall 2017 IUPUI, Team S1-G1, Baechle Fall 2017 üyesi
IUPUI-BAECHLE-F17S1G1
2 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 10
Son 30 Gün: 80
Her zaman: 1,635
