Ana içeriğe geç
Astro C40 TR Joystick Replacement
Neye ihtiyacın var
  1. Astro C40 TR Joystick Replacement, Joystick: adım 1, 1 resimden 1.
    • Unplug your controller from the video game console.
    • Turn the wireless mode off if it is activated on your controller.
  2. Astro C40 TR Joystick Replacement: adım 2, 3 resimden 1. Astro C40 TR Joystick Replacement: adım 2, 3 resimden 2. Astro C40 TR Joystick Replacement: adım 2, 3 resimden 3.
    • Use an H.20 Hexagonal screwdriver to loosen the two screws on each joystick's side.
    • Remove the face cover of the joystick by flipping the controller on its side.
    • Don't panic if the joystick falls off! It can be placed back on.
  3. Astro C40 TR Joystick Replacement: adım 3, 3 resimden 1. Astro C40 TR Joystick Replacement: adım 3, 3 resimden 2. Astro C40 TR Joystick Replacement: adım 3, 3 resimden 3.
    • Use the 30mm TORX Screwdriver to remove the screws from the module.
    • Push on the top frame until it pops off of the module.
    • If you have a whole new joystick module, you can skip to step 6.
  4. Astro C40 TR Joystick Replacement: adım 4, 3 resimden 1. Astro C40 TR Joystick Replacement: adım 4, 3 resimden 2. Astro C40 TR Joystick Replacement: adım 4, 3 resimden 3.
    • Connect the base frame replacement to the joystick module.
    • Insert the top frame on the module until it clicks back together.
  5. Astro C40 TR Joystick Replacement: adım 5, 3 resimden 1. Astro C40 TR Joystick Replacement: adım 5, 3 resimden 2. Astro C40 TR Joystick Replacement: adım 5, 3 resimden 3.
    • Reassemble the joystick module and plug it back into the controller.
    • Make sure the replacement and base frame are tightly screwed together.
    • Align the module and controller as you put joystick back together.
  6. Astro C40 TR Joystick Replacement: adım 6, 2 resimden 1. Astro C40 TR Joystick Replacement: adım 6, 2 resimden 2.
    • Reassemble the controller by placing the face cover back on.
    • Tighten the screws on the face cover with the H.20 Hexagonal Screwdriver.
    • If it's difficult to tighten the screws, don't force it. The joystick and controller are probably not aligned correctly!
  7. Astro C40 TR Joystick Replacement: adım 7, 1 resimden 1.
    • Recalibrate the controller so the new joystick can be detected by the console.
    • Connect the controller to the console and activate wire-connect mode by clicking the controller's top right corner.
    • Push the button on the back of the controller. Hold it until the controller vibrates. Release the button and repeat.
Sonuç
Pan
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 122
Her zaman: 3,196
