Ana içeriğe geç
Astro Mixamp Control Button Replacement
Neye ihtiyacın var
  1. Astro Mixamp Control Button Replacement, Panel Dial: adım 1, 2 resimden 1. Astro Mixamp Control Button Replacement, Panel Dial: adım 1, 2 resimden 2.
    • Grip the dial tightly and pull straight off the device.
    • Repeat for the second dial
    FixBot'a Sor
    Yorum Ekle
  2. Astro Mixamp Control Button Replacement: adım 2, 2 resimden 1. Astro Mixamp Control Button Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the spacer nuts and washers from each dial post.
    FixBot'a Sor
    Yorum Ekle
  3. Astro Mixamp Control Button Replacement, Outer Casing: adım 3, 2 resimden 1. Astro Mixamp Control Button Replacement, Outer Casing: adım 3, 2 resimden 2.
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
    FixBot'a Sor
    Yorum Ekle
  4. Astro Mixamp Control Button Replacement: adım 4, 1 resimden 1.
    • Use a screwdriver to remove the screw from the rear casing.
    FixBot'a Sor
    Yorum Ekle
  5. Astro Mixamp Control Button Replacement: adım 5, 1 resimden 1.
    • Gently lift the rear casing from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Astro Mixamp Control Button Replacement, Motherboard: adım 6, 3 resimden 1. Astro Mixamp Control Button Replacement, Motherboard: adım 6, 3 resimden 2. Astro Mixamp Control Button Replacement, Motherboard: adım 6, 3 resimden 3.
    • Remove the four screws that hold the motherboard in place.
    • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Astro Mixamp Control Button Replacement: adım 7, 1 resimden 1.
    • Gently pull the motherboard from the front cover.
    FixBot'a Sor
    Yorum Ekle
  8. Astro Mixamp Control Button Replacement, Control Button: adım 8, 2 resimden 1. Astro Mixamp Control Button Replacement, Control Button: adım 8, 2 resimden 2.
    • Gently insert a metal spudger under a control button housing.
    • Do not pry the button housing from the front panel, this can cause damage to the button.
    • Rotate the control button around the marked pin.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Hope Burns
741 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 45
Her zaman: 2,059
