Ana içeriğe geç
Astro Pyle PTBL7C Speakers Replacement
Neye ihtiyacın var
  1. Astro Pyle PTBL7C Speakers Replacement, Case Separation: adım 1, 2 resimden 1. Astro Pyle PTBL7C Speakers Replacement, Case Separation: adım 1, 2 resimden 2.
    • Slide the flat end of the spudger under the front edge of the screen and carefully pry it open.
    • The front edge is the side with the buttons on it.
    • You may hear a cracking sound when pulling the case off of the device. This is normal, and is just the clips being pulled apart. However, be careful and pull the clips slowly/cautiously to avoid damage.
    • Be aware of the speaker cable when removing the case, as it is still attached to the motherboard.
  2. Astro Pyle PTBL7C Speakers Replacement, Tape Removal: adım 2, 1 resimden 1.
    • Locate the Speakers; they should be attached to the case as shown.
    • Follow the wires back to the motherboard, removing all tape covering the wires along the way.
    • This will make it easier to move the wires around.
    • Desolder the black wire from the motherboard. This will separate the speakers from the board, allowing you to replace them.
    • Exercise EXTREME caution while soldering. It is very easy to burn yourself, or damage the surrounding components. For a basic guide of how to desolder, follow this link: http://www.dummies.com/programming/elect...
Sonuç
Abdulelah
214 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 5-5, Wilson Fall 2016 IUPUI, Team 5-5, Wilson Fall 2016 üyesi
IUPUI-WILSON-F16S5G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 222
