Ana içeriğe geç
Asus 1015E-DS03 Keyboard Replacement
Neye ihtiyacın var
  1. Asus 1015E-DS03 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Hold the laptop using both hands with the battery facing upwards.
    FixBot'a Sor
    Yorum Ekle
  2. Asus 1015E-DS03 Keyboard Replacement: adım 2, 1 resimden 1.
    • Push the two tabs located below the battery in towards each other using your thumbs.
    FixBot'a Sor
    Yorum Ekle
  3. Asus 1015E-DS03 Keyboard Replacement: adım 3, 1 resimden 1.
    • Push the battery upwards and out of the laptop as shown.
    FixBot'a Sor
    Yorum Ekle
  4. Asus 1015E-DS03 Keyboard Replacement: adım 4, 1 resimden 1.
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
    FixBot'a Sor
    Yorum Ekle
  5. Asus 1015E-DS03 Keyboard Replacement, Keyboard: adım 5, 1 resimden 1.
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
    FixBot'a Sor
    Yorum Ekle
  6. Asus 1015E-DS03 Keyboard Replacement: adım 6, 2 resimden 1. Asus 1015E-DS03 Keyboard Replacement: adım 6, 2 resimden 2.
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
    FixBot'a Sor
    Yorum Ekle
  7. Asus 1015E-DS03 Keyboard Replacement: adım 7, 1 resimden 1.
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  8. Asus 1015E-DS03 Keyboard Replacement: adım 8, 1 resimden 1.
    • Using the spudger push the white clips upwards that are holding the cable.
    FixBot'a Sor
    Yorum Ekle
  9. Asus 1015E-DS03 Keyboard Replacement: adım 9, 2 resimden 1. Asus 1015E-DS03 Keyboard Replacement: adım 9, 2 resimden 2.
    • Gently pull the strip out of the square slot.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Joe Capriola
494 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 7-4, Benson Spring 2016 Clemson, Team 7-4, Benson Spring 2016 üyesi
CLEM-BENSON-S16S7G4
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 48
Her zaman: 1,580
