Giriş
This guide will demonstrate how to remove the motherboard. A spudger and screwdriver will be used.
Neye ihtiyacın var
Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
Remove the 3mm screws (8) from the motherboard using a #0 Phillips head screwdriver.
Carefully and slowly lift the motherboard out of the base of the laptop.
2 farklı kişi bu kılavuzu tamamladı.
