Ana içeriğe geç
Asus 1015E-DS03 Screen Replacement
Neye ihtiyacın var
  1. Asus 1015E-DS03 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Hold the laptop using both hands with the battery facing upwards.
    FixBot'a Sor
    Yorum Ekle
  2. Asus 1015E-DS03 Screen Replacement: adım 2, 1 resimden 1.
    • Push the two tabs located below the battery in towards each other using your thumbs.
    FixBot'a Sor
    Yorum Ekle
  3. Asus 1015E-DS03 Screen Replacement: adım 3, 1 resimden 1.
    • Push the battery upwards and out of the laptop as shown.
    FixBot'a Sor
    Yorum Ekle
  4. Asus 1015E-DS03 Screen Replacement: adım 4, 1 resimden 1.
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
    FixBot'a Sor
    Yorum Ekle
  5. Asus 1015E-DS03 Screen Replacement, Front Screen Case: adım 5, 1 resimden 1.
    • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
    • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
    FixBot'a Sor
    Yorum Ekle
  6. Asus 1015E-DS03 Screen Replacement: adım 6, 2 resimden 1. Asus 1015E-DS03 Screen Replacement: adım 6, 2 resimden 2.
    • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
    • You will hear popping noises which are to be expected.
    FixBot'a Sor
    Yorum Ekle
  7. Asus 1015E-DS03 Screen Replacement: adım 7, 1 resimden 1.
    • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
    FixBot'a Sor
    Yorum Ekle
  8. Asus 1015E-DS03 Screen Replacement, Screen: adım 8, 1 resimden 1.
    • Unscrew the 3 mm screws (4) using a #0 Phillips head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Asus 1015E-DS03 Screen Replacement: adım 9, 2 resimden 1. Asus 1015E-DS03 Screen Replacement: adım 9, 2 resimden 2.
    • Lift the screen away from the computer.
    • Be careful removing the screen, as the left side is still connected to the computer.
    FixBot'a Sor
    Yorum Ekle
  10. Asus 1015E-DS03 Screen Replacement: adım 10, 2 resimden 1. Asus 1015E-DS03 Screen Replacement: adım 10, 2 resimden 2.
    • Remove the wire that is glued to the back of the screen with your fingers.
    • Remove the tape covering the connection port.
    FixBot'a Sor
    Yorum Ekle
  11. Asus 1015E-DS03 Screen Replacement: adım 11, 1 resimden 1.
    • Separate the screen from the computer by gently pulling it out.
    FixBot'a Sor
    Yorum Ekle
  12. Asus 1015E-DS03 Screen Replacement: adım 12, 1 resimden 1.
    • Upon removal, the computer should look like this picture.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Becca Day
321 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 7-4, Benson Spring 2016 Clemson, Team 7-4, Benson Spring 2016 üyesi
CLEM-BENSON-S16S7G4
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 41
Her zaman: 1,102
