Ana içeriğe geç
Asus 1015E-DS03 Trackpad Replacement
Neye ihtiyacın var
  1. Asus 1015E-DS03 Trackpad Replacement, Battery: adım 1, 1 resimden 1.
    • Hold the laptop using both hands with the battery facing upwards.
    FixBot'a Sor
    Yorum Ekle
  2. Asus 1015E-DS03 Trackpad Replacement: adım 2, 1 resimden 1.
    • Push the two tabs located below the battery in towards each other using your thumbs.
    FixBot'a Sor
    Yorum Ekle
  3. Asus 1015E-DS03 Trackpad Replacement: adım 3, 1 resimden 1.
    • Push the battery upwards and out of the laptop as shown.
    FixBot'a Sor
    Yorum Ekle
  4. Asus 1015E-DS03 Trackpad Replacement: adım 4, 1 resimden 1.
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
    FixBot'a Sor
    Yorum Ekle
  5. Asus 1015E-DS03 Trackpad Replacement, Keyboard: adım 5, 1 resimden 1.
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
    FixBot'a Sor
    Yorum Ekle
  6. Asus 1015E-DS03 Trackpad Replacement: adım 6, 2 resimden 1. Asus 1015E-DS03 Trackpad Replacement: adım 6, 2 resimden 2.
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
    FixBot'a Sor
    Yorum Ekle
  7. Asus 1015E-DS03 Trackpad Replacement: adım 7, 1 resimden 1.
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  8. Asus 1015E-DS03 Trackpad Replacement: adım 8, 1 resimden 1.
    • Using the spudger push the white clips upwards that are holding the cable.
    FixBot'a Sor
    Yorum Ekle
  9. Asus 1015E-DS03 Trackpad Replacement: adım 9, 2 resimden 1. Asus 1015E-DS03 Trackpad Replacement: adım 9, 2 resimden 2.
    • Gently pull the strip out of the square slot.
    FixBot'a Sor
    Yorum Ekle
  10. Asus 1015E-DS03 Trackpad Replacement, Trackpad: adım 10, 1 resimden 1.
    • Unscrew all of the indicated 5mm screws (11) using a #0 Philips head screwdriver.
    • One of the screws will be covered by a sticker indicating that proceeding will void the warranty.
    FixBot'a Sor
    Yorum Ekle
  11. Asus 1015E-DS03 Trackpad Replacement: adım 11, 2 resimden 1. Asus 1015E-DS03 Trackpad Replacement: adım 11, 2 resimden 2.
    • Before the baseboard can be fully removed from the laptop, you need to detach the small blue tab attached to the motherboard.
    • Gently lift up on the black plastic tab that is securing the blue tab in place.
    • Carefully pull the blue tab out of the dock.
    FixBot'a Sor
    Yorum Ekle
  12. Asus 1015E-DS03 Trackpad Replacement: adım 12, 2 resimden 1. Asus 1015E-DS03 Trackpad Replacement: adım 12, 2 resimden 2.
    • Use the spudger from the laptop to 'pop' open the track-pad base, starting from the corner shown
    • Once the corner is popped it may be easier to use your fingers to pop off the entire track-pad base
    • You will hear popping. Although this is normal, use caution pulling the track-pad base from the rest of the laptop
    FixBot'a Sor
    Yorum Ekle
  13. Asus 1015E-DS03 Trackpad Replacement: adım 13, 3 resimden 1. Asus 1015E-DS03 Trackpad Replacement: adım 13, 3 resimden 2. Asus 1015E-DS03 Trackpad Replacement: adım 13, 3 resimden 3.
    • Once the trackpad base is detached, flip it face-down.
    • Lift the small black tab that the blue flat cable is attached to.
    FixBot'a Sor
    Yorum Ekle
  14. Asus 1015E-DS03 Trackpad Replacement: adım 14, 1 resimden 1.
    • Remove the 3mm screws (3) circled in red with a #0 Phillips head screwdriver.
    • The metal plate shown in blue will fall off by itself, replace it before re-securing the baseplate.
    FixBot'a Sor
    Yorum Ekle
  15. Asus 1015E-DS03 Trackpad Replacement: adım 15, 3 resimden 1. Asus 1015E-DS03 Trackpad Replacement: adım 15, 3 resimden 2. Asus 1015E-DS03 Trackpad Replacement: adım 15, 3 resimden 3.
    • Detach the tape connecting the trackpad to the trackpad base, and carefully remove the trackpad.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Liam Monteith
149 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 7-4, Benson Spring 2016 Clemson, Team 7-4, Benson Spring 2016 üyesi
CLEM-BENSON-S16S7G4
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 50
Her zaman: 917
