Giriş
If the trackpad is not working correctly, it may need to be replaced. The following guide shows the user how to remove the trackpad. A spudger will be needed to remove the trackpad.
Neye ihtiyacın var
Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
Unscrew all of the indicated 5mm screws (11) using a #0 Philips head screwdriver.
Bir başkası bu kılavuzu tamamladı.
