Ana içeriğe geç
Asus A52F Cooling System Replacement
Neye ihtiyacın var
  1. Asus A52F Cooling System Replacement, Battery: adım 1, 2 resimden 1. Asus A52F Cooling System Replacement, Battery: adım 1, 2 resimden 2.
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
    FixBot'a Sor
    Yorum Ekle
  2. Asus A52F Cooling System Replacement: adım 2, 2 resimden 1. Asus A52F Cooling System Replacement: adım 2, 2 resimden 2.
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
    FixBot'a Sor
    Yorum Ekle
  3. Asus A52F Cooling System Replacement, Lower Case: adım 3, 3 resimden 1. Asus A52F Cooling System Replacement, Lower Case: adım 3, 3 resimden 2. Asus A52F Cooling System Replacement, Lower Case: adım 3, 3 resimden 3.
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
    FixBot'a Sor
    Yorum Ekle
  4. Asus A52F Cooling System Replacement: adım 4, 2 resimden 1. Asus A52F Cooling System Replacement: adım 4, 2 resimden 2.
    • Slide the back panel away and remove the panel.
    FixBot'a Sor
    Yorum Ekle
  5. Asus A52F Cooling System Replacement, Cooling System: adım 5, 2 resimden 1. Asus A52F Cooling System Replacement, Cooling System: adım 5, 2 resimden 2.
    • Removal of cooling system will void your warranty. Proceed with caution.
    FixBot'a Sor
    Yorum Ekle
  6. Asus A52F Cooling System Replacement: adım 6, 2 resimden 1. Asus A52F Cooling System Replacement: adım 6, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove all six screws from the cooling system.
    • Unplug the fan power connector.
    FixBot'a Sor
    Yorum Ekle
  7. Asus A52F Cooling System Replacement: adım 7, 2 resimden 1. Asus A52F Cooling System Replacement: adım 7, 2 resimden 2.
    • Carefully grab the copper pipe and start to lift upward.
    • Lift to the angle shown and then start to slide it out.
    FixBot'a Sor
    Yorum Ekle
  8. Asus A52F Cooling System Replacement: adım 8, 1 resimden 1.
    • Clean the designated area with isopropyl alcohol on a microfiber cloth
    • Replace with new thermal paste if needed
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bradley Varnum
345 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G1, Botvin Spring 2017 UMass Dartmouth, Team S5-G1, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S5G1
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,292
