Ana içeriğe geç
Asus A52F Hard Drive Replacement
Neye ihtiyacın var
  1. Asus A52F Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Asus A52F Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Hard Drive Replacement: adım 2, 2 resimden 1. Asus A52F Hard Drive Replacement: adım 2, 2 resimden 2.
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Hard Drive Replacement, Lower Case: adım 3, 3 resimden 1. Asus A52F Hard Drive Replacement, Lower Case: adım 3, 3 resimden 2. Asus A52F Hard Drive Replacement, Lower Case: adım 3, 3 resimden 3.
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Hard Drive Replacement: adım 4, 2 resimden 1. Asus A52F Hard Drive Replacement: adım 4, 2 resimden 2.
    • Slide the back panel away and remove the panel.
  5. Asus A52F Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 1. Asus A52F Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 2. Asus A52F Hard Drive Replacement, Hard Drive: adım 5, 3 resimden 3.
    • Remove the four Phillips #0 screws holding the hard drive case to the laptop.
    • Lift the hard drive upwards by the two arms in order to remove the hard drive case from the laptop.
  6. Asus A52F Hard Drive Replacement: adım 6, 2 resimden 1. Asus A52F Hard Drive Replacement: adım 6, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the cage screws on the side of the hard drive.
  7. Asus A52F Hard Drive Replacement: adım 7, 2 resimden 1. Asus A52F Hard Drive Replacement: adım 7, 2 resimden 2.
    • Next, slide the case off of the broken hard drive.
    • Slide the working hard drive into the case and screw it on.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Roman Justice
225 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G1, Botvin Spring 2017 UMass Dartmouth, Team S5-G1, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S5G1
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 21
Her zaman: 1,538
