Ana içeriğe geç
Asus A52F Wifi Card Replacement
Neye ihtiyacın var
  1. Asus A52F Wifi Card Replacement, Battery: adım 1, 2 resimden 1. Asus A52F Wifi Card Replacement, Battery: adım 1, 2 resimden 2.
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
    FixBot'a Sor
    Yorum Ekle
  2. Asus A52F Wifi Card Replacement: adım 2, 2 resimden 1. Asus A52F Wifi Card Replacement: adım 2, 2 resimden 2.
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
    FixBot'a Sor
    Yorum Ekle
  3. Asus A52F Wifi Card Replacement, Lower Case: adım 3, 3 resimden 1. Asus A52F Wifi Card Replacement, Lower Case: adım 3, 3 resimden 2. Asus A52F Wifi Card Replacement, Lower Case: adım 3, 3 resimden 3.
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
    FixBot'a Sor
    Yorum Ekle
  4. Asus A52F Wifi Card Replacement: adım 4, 2 resimden 1. Asus A52F Wifi Card Replacement: adım 4, 2 resimden 2.
    • Slide the back panel away and remove the panel.
    FixBot'a Sor
    Yorum Ekle
  5. Asus A52F Wifi Card Replacement, Wifi Card: adım 5, 2 resimden 1. Asus A52F Wifi Card Replacement, Wifi Card: adım 5, 2 resimden 2.
    • First, find the Wi-Fi card
    • Move the protective flap back and use a Phillips size 0 screw driver to remove the two screws.
    FixBot'a Sor
    Yorum Ekle
  6. Asus A52F Wifi Card Replacement: adım 6, 3 resimden 1. Asus A52F Wifi Card Replacement: adım 6, 3 resimden 2. Asus A52F Wifi Card Replacement: adım 6, 3 resimden 3.
    • First remove both of the wires from the WiFi card.
    • Lift the WiFi card up and remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Roman Justice
255 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G1, Botvin Spring 2017 UMass Dartmouth, Team S5-G1, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S5G1
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 44
Her zaman: 2,307
