Giriş
In this guide, the steps on how to remove the ASUS A53S Motherboard and replace the board will be thoroughly outlined, with pictures associated with each step being provided. The motherboard of the computer is an incredibly important component, as the motherboard resembles the "heart" of the computer allowing everything to function. If any problems are encountered with the motherboard, detrimental problems to your PC can be caused which can be as severe as the computer not operating whatsoever. To get started on how to solve the problem, click on the troubleshooting link here:
Asus A53S Motherboard Replacement
Neye ihtiyacın var
Flip the laptop so the underside is facing up.
Using a Phillips #01 screwdriver, unscrew the two 6 mm screws.
Bir başkası bu kılavuzu tamamladı.
