Ana içeriğe geç
Asus A53U-ES21 Keyboard Replacement
Neye ihtiyacın var
  1. Asus A53U-ES21 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Asus A53U-ES21 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
    FixBot'a Sor
    Yorum Ekle
  2. Asus A53U-ES21 Keyboard Replacement: adım 2, 2 resimden 1. Asus A53U-ES21 Keyboard Replacement: adım 2, 2 resimden 2.
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
    FixBot'a Sor
    Yorum Ekle
  3. Asus A53U-ES21 Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Asus A53U-ES21 Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Asus A53U-ES21 Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Asus A53U-ES21 Keyboard Replacement: adım 4, 3 resimden 1. Asus A53U-ES21 Keyboard Replacement: adım 4, 3 resimden 2. Asus A53U-ES21 Keyboard Replacement: adım 4, 3 resimden 3.
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
    FixBot'a Sor
    Yorum Ekle
  5. Asus A53U-ES21 Keyboard Replacement: adım 5, 3 resimden 1. Asus A53U-ES21 Keyboard Replacement: adım 5, 3 resimden 2. Asus A53U-ES21 Keyboard Replacement: adım 5, 3 resimden 3.
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Mabel Trager
180 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 UMass Dartmouth, Team S1-G3, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G3
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 27
Her zaman: 916
