Ana içeriğe geç
Asus A53U-ES21 Optical Drive Replacement
Neye ihtiyacın var
  1. Asus A53U-ES21 Optical Drive Replacement, Battery: adım 1, 2 resimden 1. Asus A53U-ES21 Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
    FixBot'a Sor
    Yorum Ekle
  2. Asus A53U-ES21 Optical Drive Replacement: adım 2, 2 resimden 1. Asus A53U-ES21 Optical Drive Replacement: adım 2, 2 resimden 2.
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
    FixBot'a Sor
    Yorum Ekle
  3. Asus A53U-ES21 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 1. Asus A53U-ES21 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 2. Asus A53U-ES21 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the RAM panel.
    FixBot'a Sor
    Yorum Ekle
  4. Asus A53U-ES21 Optical Drive Replacement: adım 4, 3 resimden 1. Asus A53U-ES21 Optical Drive Replacement: adım 4, 3 resimden 2. Asus A53U-ES21 Optical Drive Replacement: adım 4, 3 resimden 3.
    • Remove the 7mm screw using a Phillips #1 screwdriver.
    • Pull the optical drive out from the side of the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Chase Poirier
585 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 UMass Dartmouth, Team S1-G3, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G3
3 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 583
