Ana içeriğe geç
Asus A53U-ES21 Wireless Card Replacement
Neye ihtiyacın var
  1. Asus A53U-ES21 Wireless Card Replacement, Battery: adım 1, 2 resimden 1. Asus A53U-ES21 Wireless Card Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Wireless Card Replacement: adım 2, 2 resimden 1. Asus A53U-ES21 Wireless Card Replacement: adım 2, 2 resimden 2.
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 1. Asus A53U-ES21 Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 2. Asus A53U-ES21 Wireless Card Replacement, Wireless Card: adım 3, 3 resimden 3.
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the panel.
  4. Asus A53U-ES21 Wireless Card Replacement: adım 4, 3 resimden 1. Asus A53U-ES21 Wireless Card Replacement: adım 4, 3 resimden 2. Asus A53U-ES21 Wireless Card Replacement: adım 4, 3 resimden 3.
    • Detach the two cables connected to the wireless card (the opening tool works well for this).
    • Remove the 4mm screw (highlighted in orange).
    • Pull the wireless card up and remove it from the device.
Sonuç
Chase Poirier
544 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 UMass Dartmouth, Team S1-G3, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G3
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 273
