Ana içeriğe geç
Asus CM1745 Case Fan Replacement
Neye ihtiyacın var
  1. Asus CM1745 Case Fan Replacement, Case Fan: adım 1, 2 resimden 1. Asus CM1745 Case Fan Replacement, Case Fan: adım 1, 2 resimden 2.
    • Remove the side panel by unscrewing the two screws fastening the panel on the rear.
    • Once unscrewed, slide the panel towards the rear until it releases then lift away.
    FixBot'a Sor
    Yorum Ekle
  2. Asus CM1745 Case Fan Replacement: adım 2, 3 resimden 1. Asus CM1745 Case Fan Replacement: adım 2, 3 resimden 2. Asus CM1745 Case Fan Replacement: adım 2, 3 resimden 3.
    • Remove the 3-pin fan connector from the 4-pin fan header on the motherboard by lightly pulling on the white plastic connector.
    FixBot'a Sor
    Yorum Ekle
  3. Asus CM1745 Case Fan Replacement: adım 3, 3 resimden 1. Asus CM1745 Case Fan Replacement: adım 3, 3 resimden 2. Asus CM1745 Case Fan Replacement: adım 3, 3 resimden 3.
    • Remove the four screws on the rear of the case. Keep the fan still by holding onto it with a spare hand.
    • Once the screws are removed, carefully lift the fan and its cable out, remembering its orientation.
    FixBot'a Sor
    Yorum Ekle
  4. Asus CM1745 Case Fan Replacement: adım 4, 3 resimden 1. Asus CM1745 Case Fan Replacement: adım 4, 3 resimden 2. Asus CM1745 Case Fan Replacement: adım 4, 3 resimden 3.
    • Take your replacement case fan and orient it in the same way as the previous fan.
    • Using the screws you just removed, secure the fan in place and reconnect to the fan header.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Once finished, plug in the computer and turn it on to test if the new fan works and is installed correctly. If everything works as it should, replace the side panel and resecure the screws in the rear.
2 farklı kişi bu kılavuzu tamamladı.
TC Fowlar
896 İtibar
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 17
Son 30 gün: 51
Her zaman: 2,313
