Ana içeriğe geç
Asus Chromebook C101P Keyboard Replacement
Neye ihtiyacın var
  1. Asus Chromebook C101P Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Chromebook C101P Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Chromebook C101P Keyboard Replacement: adım 3, 1 resimden 1.
    • Remove the four black screws where the rubber grips were.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Chromebook C101P Keyboard Replacement: adım 4, 2 resimden 1. Asus Chromebook C101P Keyboard Replacement: adım 4, 2 resimden 2.
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Chromebook C101P Keyboard Replacement: adım 5, 3 resimden 1. Asus Chromebook C101P Keyboard Replacement: adım 5, 3 resimden 2. Asus Chromebook C101P Keyboard Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Bryan Acosta
401 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G2
2 Üyeler
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
This did not work my laptop won't turn on now. Any suggestions?
Destiny Wright - Yanıt Paylaş
We’re sorry to hear that. We recommend you contact iFixit directly for support on this issue or to contact ASUS for further help.
Bryan Acosta - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 38
Her zaman: 2,158
