Ana içeriğe geç
Asus Chromebook C201 LCD Screen Replacement
Neye ihtiyacın var
  1. Asus Chromebook C201 LCD Screen Replacement, Palm Rest Assembly: adım 1, 1 resimden 1.
    • Flip the laptop upside down with the rear end of the computer away from you.
  2. Asus Chromebook C201 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
  3. Asus Chromebook C201 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
  4. Asus Chromebook C201 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
  5. Asus Chromebook C201 LCD Screen Replacement: adım 5, 2 resimden 1. Asus Chromebook C201 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
  6. Asus Chromebook C201 LCD Screen Replacement: adım 6, 3 resimden 1. Asus Chromebook C201 LCD Screen Replacement: adım 6, 3 resimden 2. Asus Chromebook C201 LCD Screen Replacement: adım 6, 3 resimden 3.
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
  7. Asus Chromebook C201 LCD Screen Replacement: adım 7, 2 resimden 1. Asus Chromebook C201 LCD Screen Replacement: adım 7, 2 resimden 2.
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
  8. Asus Chromebook C201 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Remove the keyboard cover and safely place it somewhere face down.
  9. Asus Chromebook C201 LCD Screen Replacement, LCD Screen: adım 9, 2 resimden 1. Asus Chromebook C201 LCD Screen Replacement, LCD Screen: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the LCD cable and its connector which is located in the upper left hand corner of the computer. Carefully flip up the tiny tab and safely remove the cable using precision tweezers.
  10. Asus Chromebook C201 LCD Screen Replacement: adım 10, 2 resimden 1. Asus Chromebook C201 LCD Screen Replacement: adım 10, 2 resimden 2.
    • Disconnect the black and white cables located near the screen hinge.
  11. Asus Chromebook C201 LCD Screen Replacement: adım 11, 2 resimden 1. Asus Chromebook C201 LCD Screen Replacement: adım 11, 2 resimden 2.
    • Remove the 6, 4mm silver screws from the hinges attaching the LCD to the laptop using the J0 Phillips screwdriver.
  12. Asus Chromebook C201 LCD Screen Replacement: adım 12, 1 resimden 1.
    • Turn the hinges to an upright position.
  13. Asus Chromebook C201 LCD Screen Replacement: adım 13, 2 resimden 1. Asus Chromebook C201 LCD Screen Replacement: adım 13, 2 resimden 2.
    • Carefully pop the LCD screen assembly out of the laptop case.
  14. Asus Chromebook C201 LCD Screen Replacement: adım 14, 2 resimden 1. Asus Chromebook C201 LCD Screen Replacement: adım 14, 2 resimden 2.
    • Remove the silver cover.
    • Make sure to put the cover back in right side (longer side) up when re-installing
  15. Asus Chromebook C201 LCD Screen Replacement: adım 15, 2 resimden 1. Asus Chromebook C201 LCD Screen Replacement: adım 15, 2 resimden 2.
    • Use a blue plastic spudger to snap the LCD cover off, working the spudger around the perimeter and completely remove the cover.
  16. Asus Chromebook C201 LCD Screen Replacement: adım 16, 1 resimden 1.
    • Remove the 4, 3mm silver corner screws holding in the LCD.
  17. Asus Chromebook C201 LCD Screen Replacement: adım 17, 2 resimden 1. Asus Chromebook C201 LCD Screen Replacement: adım 17, 2 resimden 2.
    • Remove the left hinge by unscrewing the two 3mm large Phillips head screws.
    • Unscrew the one 3mm small Phillips head screw.
  18. Asus Chromebook C201 LCD Screen Replacement: adım 18, 2 resimden 1. Asus Chromebook C201 LCD Screen Replacement: adım 18, 2 resimden 2.
    • Carefully lift the screen. Gently unravel and unplug the LCD cord.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Taylor Allen
327 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-51, Cagle Spring 2016 USF Tampa, Team 2-51, Cagle Spring 2016 üyesi
USFT-CAGLE-S16S2G51
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 3,849
