Giriş
If your Chromebook needs opened or you are having issues with the touchpad, then this guide is going to help you remove or replace your palm rest assembly. When working on replacing your palm rest assembly, be sure to ground yourself. Static can short circuit your Chromebook, so be sure to either wear an anti-static wrist strap or work on a surface that doesn't generate static electricity, like wood, tile, or other hard floors.
Neye ihtiyacın var
Flip the laptop upside down with the rear end of the computer away from you.
2 farklı kişi bu kılavuzu tamamladı.
