Ana içeriğe geç
Asus Chromebook C201PA-DS02-LG Battery Replacement
Neye ihtiyacın var
  1. Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: adım 1, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: adım 1, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: adım 1, 3 resimden 3.
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 2, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 3, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 4, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 4, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 4, 3 resimden 3.
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 5, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 5, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: adım 6, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: adım 6, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: adım 6, 3 resimden 3.
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: adım 7, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: adım 7, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: adım 7, 3 resimden 3.
    • Use a Phillips #0 screwdriver to unscrew the 4mm screws. Rotate the screwdriver in a counterclockwise direction to undo the screws.
    • Remove the rainbow connector by firmly grasping the rainbow wires and pulling straight back. It will help to brace the motherboard when you pull.
  8. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 8, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Battery Replacement: adım 8, 2 resimden 2.
    • Use the plastic opening tool to lift up the battery and remove it.
    • Do not dispose of the battery in normal waste. The chemicals inside are toxic. Find out where to dispose of properly in your neighborhood.
Sonuç
Ashley Humpal
185 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G4, Livingston Spring 2018 Cal Poly, Team S17-G4, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S17G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 339
