Ana içeriğe geç
Asus Chromebook C201PA-DS02-LG Daughterboard Replacement
Neye ihtiyacın var
  1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Keyboard: adım 1, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Keyboard: adım 1, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 2, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 3, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 4, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 4, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 4, 3 resimden 3.
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 5, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 5, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Metal Plate: adım 6, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Metal Plate: adım 6, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Metal Plate: adım 6, 3 resimden 3.
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Daughterboard: adım 7, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Daughterboard: adım 7, 2 resimden 2.
    • Use a Phillips #0 screwdriver to unscrew the two 4mm screws.
    • Flip up the white tab to remove the white ribbon cable.
  8. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 8, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 8, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 8, 3 resimden 3.
    • Use a plastic opening tool to flip up the connector connecting the slim blue tipped strip to the daughterboard.
    • Lift the slim blue tipped strip from the daughterboard.
  9. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 9, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 9, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: adım 9, 3 resimden 3.
    • Place the plastic opening tools underneath the daughterboard.
    • Gently lift the daughterboard from the base of the device.
Sonuç
Brittany M Won
577 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G4, Livingston Spring 2018 Cal Poly, Team S17-G4, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S17G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 154
