Ana içeriğe geç
Asus Chromebook C201PA-DS02-LG Motherboard Replacement
Neye ihtiyacın var
  1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Keyboard: adım 1, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Keyboard: adım 1, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 2, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 3, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 4, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 4, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 4, 3 resimden 3.
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 5, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 5, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Metal Plate: adım 6, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Metal Plate: adım 6, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Metal Plate: adım 6, 3 resimden 3.
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Use a Phillips #0 screwdriver to unscrew the 4mm screw. Rotate the screwdriver in a counterclockwise direction to undo the screw.
  8. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 8, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 8, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to gently pull upward on the adhesive black tape.
  9. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 9, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 9, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 9, 3 resimden 3.
    • Use tweezers to pull upward and pop off the wifi antenna cables.
    • Removing the cables may cause popping noises.
  10. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 10, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 10, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 10, 3 resimden 3.
    • Use tweezers to gently pull upward and pop off the LCD cable. It may help to do this on each side of the attachment, rather than in one pull.
    • Removing the cable may cause popping noises.
  11. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 11, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 11, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 11, 3 resimden 3.
  12. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 12, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 12, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 12, 3 resimden 3.
    • Remove the rainbow connector by firmly grasping the rainbow wires and pulling straight back. It will help to brace the motherboard when you pull.
  13. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 13, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 13, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 13, 3 resimden 3.
    • Use tweezers to gently grasp the wire connector and pull straight back.
  14. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 14, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 14, 2 resimden 2.
    • Use a Phillips #0 screwdriver to unscrew the 4mm screws. Rotate the screwdriver in a counterclockwise direction to undo the screws.
    • One of the screws may be hidden underneath the black LCD connector.
  15. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: adım 15, 1 resimden 1.
    • Use a plastic opening tool to lift the motherboard off the bottom. You may need to wiggle it around to get it loose.
Sonuç
Brittany M Won
577 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G4, Livingston Spring 2018 Cal Poly, Team S17-G4, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S17G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 334
