Giriş
This guide details how to replace the screen if it is cracked or not working properly. During this process be sure to avoid resting your arm or hand in the adhesive on the motherboard.
Neye ihtiyacın var
Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
Wiggle the plate back and forth to loosen the adhesive under the plate.
Rotate the screwdriver in a counterclockwise direction to remove the screws.
Unscrew the 4mm screws with a Phillips #0 screwdriver by rotating the screwdriver counterclockwise.
