Ana içeriğe geç
Asus Chromebook C201PA-DS02-LG Screen Replacement
Neye ihtiyacın var
  1. Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: adım 1, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: adım 1, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Screen Replacement, Keyboard: adım 1, 3 resimden 3.
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 2, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 3, 2 resimden 1. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 3, 2 resimden 2.
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 4, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 4, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 4, 3 resimden 3.
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 5, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 5, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 5, 3 resimden 3.
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: adım 6, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: adım 6, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Screen Replacement, Metal Plate: adım 6, 3 resimden 3.
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: adım 7, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: adım 7, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Screen Replacement, Screen: adım 7, 3 resimden 3.
    • Unscrew the 4mm screws with a Phillips #0 screwdriver by rotating the screwdriver counterclockwise.
    • There is a screw that is hidden under the black tarped connection that connects the screen to the motherboard.
  8. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 8, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 8, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift the tarp material straight up off the external output using tweezers. It is simply taped on.
  9. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 9, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 9, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 9, 3 resimden 3.
    • Use a pair of tweezers to grip the tarped connector and lift vertically up. It may help to do this on each side of the attachment, rather than in one pull.
    • Lifting the tarped connector straight up may feel like you are breaking it, but this is normal.
  10. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 10, 3 resimden 1. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 10, 3 resimden 2. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 10, 3 resimden 3.
    • Pop these two connections off by using tweezers to lift straight up.
  11. Asus Chromebook C201PA-DS02-LG Screen Replacement: adım 11, 1 resimden 1.
    • Lift the screen up to fully remove.
Sonuç
Brittany M Won
577 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S17-G4, Livingston Spring 2018 Cal Poly, Team S17-G4, Livingston Spring 2018 üyesi
CPSU-LIVINGSTON-S18S17G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 258
