Ana içeriğe geç
Asus Chromebook C202 Input/Output board Replacement
Neye ihtiyacın var
  1. Asus Chromebook C202 Input/Output board Replacement, Back Panel: adım 1, 2 resimden 1. Asus Chromebook C202 Input/Output board Replacement, Back Panel: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #1 Screwdriver
    $5.49
    Satın Al
    • Remove ten 8 mm Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
    • Two of the screws are hidden by rubber caps along the rubber rest of the device. Use tweezers to get them out.
  2. Asus Chromebook C202 Input/Output board Replacement: adım 2, 1 resimden 1.
    iFixit Opening Tool
    $1.99
    Satın Al
    • Place the plastic opening tool into the edges between the front of the Chromebook and the back of it with the upper scoop of the opening tool facing upward.
    • Push down on the plastic opening tool to unhinge the top portion of the Chromebook from its lower portion. Opening the Chromebook all the way where the display touches the ground helps in opening up the top edge.
    • Use your hand to gently lift the top portion of the Chromebook from the bottom portion of it to avoid damaging the ribbon cables.
  3. Asus Chromebook C202 Input/Output board Replacement: adım 3, 1 resimden 1.
    • Gently disconnect the ribbon cable connecting the trackpad to the motherboard.
    • Gently disconnect the ribbon cable connecting the keyboard to the motherboard.
  4. Asus Chromebook C202 Input/Output board Replacement, Battery: adım 4, 3 resimden 1. Asus Chromebook C202 Input/Output board Replacement, Battery: adım 4, 3 resimden 2. Asus Chromebook C202 Input/Output board Replacement, Battery: adım 4, 3 resimden 3.
    • Pull the latch out on both the Input/Output board as well as the motherboard.
    • Gently remove the ribbon cable connecting the I/O board to the motherboard.
  5. Asus Chromebook C202 Input/Output board Replacement: adım 5, 3 resimden 1. Asus Chromebook C202 Input/Output board Replacement: adım 5, 3 resimden 2. Asus Chromebook C202 Input/Output board Replacement: adım 5, 3 resimden 3.
    • Remove two 4 mm Phillips #1 screws from the metal grate connected to the battery.
    • Remove metal grate from battery.
    • Remove six 4 mm Phillips #1 screws from the battery
  6. Asus Chromebook C202 Input/Output board Replacement: adım 6, 2 resimden 1. Asus Chromebook C202 Input/Output board Replacement: adım 6, 2 resimden 2.
    • Disconnect the battery from the motherboard.
    • Lift battery from the bottom portion of the Chromebook.
  7. Asus Chromebook C202 Input/Output board Replacement: adım 7, 1 resimden 1.
    • Remove the battery from the Chromebook.
  8. Asus Chromebook C202 Input/Output board Replacement, Input/Output board: adım 8, 2 resimden 1. Asus Chromebook C202 Input/Output board Replacement, Input/Output board: adım 8, 2 resimden 2.
    • Remove 2 4 mm Phillips #1 screws connecting the I/O board to the Chromebook.
    • Lift the I/O board from the Chromebook.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christopher Segale
883 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Passmore Fall 2016 USF Tampa, Team 3-1, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G1
4 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
Thanks for all your ASUS guides — saved me a packet when my son breaks his!
Nick Huggett - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 1,038
