Ana içeriğe geç
Asus Chromebook C202 Motherboard Replacement
Neye ihtiyacın var
  1. Asus Chromebook C202 Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Asus Chromebook C202 Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #1 Screwdriver
    $5.49
    Satın Al
    • Remove ten 8 mm Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
    • Two of the screws are hidden by rubber caps along the rubber rest of the device. Use tweezers to get them out.
  2. Asus Chromebook C202 Motherboard Replacement: adım 2, 1 resimden 1.
    iFixit Opening Tool
    $1.99
    Satın Al
    • Place the plastic opening tool into the edges between the front of the Chromebook and the back of it with the upper scoop of the opening tool facing upward.
    • Push down on the plastic opening tool to unhinge the top portion of the Chromebook from its lower portion. Opening the Chromebook all the way where the display touches the ground helps in opening up the top edge.
    • Use your hand to gently lift the top portion of the Chromebook from the bottom portion of it to avoid damaging the ribbon cables.
  3. Asus Chromebook C202 Motherboard Replacement: adım 3, 1 resimden 1.
    • Gently disconnect the ribbon cable connecting the trackpad to the motherboard.
    • Gently disconnect the ribbon cable connecting the keyboard to the motherboard.
  4. Asus Chromebook C202 Motherboard Replacement, Wireless Card: adım 4, 1 resimden 1.
    • Remove the black and white wires from the wireless card.
  5. Asus Chromebook C202 Motherboard Replacement: adım 5, 1 resimden 1.
    • Unscrew the single 4 mm Phillips #1 screw pinning the wireless card in place.
  6. Asus Chromebook C202 Motherboard Replacement: adım 6, 1 resimden 1.
    • Gently pull the wireless card away from the motherboard.
  7. Asus Chromebook C202 Motherboard Replacement, Battery: adım 7, 3 resimden 1. Asus Chromebook C202 Motherboard Replacement, Battery: adım 7, 3 resimden 2. Asus Chromebook C202 Motherboard Replacement, Battery: adım 7, 3 resimden 3.
    • Pull the latch out on both the Input/Output board as well as the motherboard.
    • Gently remove the ribbon cable connecting the I/O board to the motherboard.
  8. Asus Chromebook C202 Motherboard Replacement: adım 8, 3 resimden 1. Asus Chromebook C202 Motherboard Replacement: adım 8, 3 resimden 2. Asus Chromebook C202 Motherboard Replacement: adım 8, 3 resimden 3.
    • Remove two 4 mm Phillips #1 screws from the metal grate connected to the battery.
    • Remove metal grate from battery.
    • Remove six 4 mm Phillips #1 screws from the battery
  9. Asus Chromebook C202 Motherboard Replacement: adım 9, 2 resimden 1. Asus Chromebook C202 Motherboard Replacement: adım 9, 2 resimden 2.
    • Disconnect the battery from the motherboard.
    • Lift battery from the bottom portion of the Chromebook.
  10. Asus Chromebook C202 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the battery from the Chromebook.
  11. Asus Chromebook C202 Motherboard Replacement, Motherboard: adım 11, 1 resimden 1.
    • Unscrew one 3 mm Phillips #1 screw.
    • Unscrew one 2.5 mm Phillips #1 screw.
    • Unscrew four 4 mm Phillips #1 screws.
  12. Asus Chromebook C202 Motherboard Replacement: adım 12, 2 resimden 1. Asus Chromebook C202 Motherboard Replacement: adım 12, 2 resimden 2.
    • Disconnect the wires that connect the motherboard to the speakers.
    • Disconnect the motherboard from the display.
  13. Asus Chromebook C202 Motherboard Replacement: adım 13, 1 resimden 1.
    • Lift the motherboard up and out of the chassis.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Segale
883 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-1, Passmore Fall 2016 USF Tampa, Team 3-1, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G1
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 66
Her zaman: 2,520
