Ana içeriğe geç
Asus Chromebook C202SA-YS02 Bezel Replacement
Neye ihtiyacın var
  1. Asus Chromebook C202SA-YS02 Bezel Replacement, Bezel: adım 1, 1 resimden 1.
    • Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
  2. Asus Chromebook C202SA-YS02 Bezel Replacement: adım 2, 1 resimden 1.
    • Unscrew and remove the two Phillips #1 4.5 mm screws that are now visible.
  3. Asus Chromebook C202SA-YS02 Bezel Replacement: adım 3, 1 resimden 1.
    • Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
Sonuç
Beau Hansen
845 İtibar
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 741
