Ana içeriğe geç
Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement
Neye ihtiyacın var
  1. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement, Keyboard: adım 1, 1 resimden 1.
    • Power off the device by pressing and holding the power button on the side of the device.
    • Remove the power cable from the back of the device (if applicable).
    • Do not move forward if your device is still on. This can cause harm to you and the device!
  2. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 2, 1 resimden 1.
    • Place the closed device on the table so that the back cover is facing up.
    • Remove the one black 4mm Phillips #00 screw on the back cover.
    • Place the iFixit opening tool in the slot and lift up the cover.
    • Slide the iFixit opening tool around the outside of the cover to remove it.
  3. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 3, 3 resimden 1. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 3, 3 resimden 2. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the seven black 4mm Phillips screws underneath the back cover.
    • Remove the eight black 7mm Phillips #00 screws along the edge of the device.
    • Remove the single silver 2mm Phillips #00 screw from the top of the Wi-Fi card.
    • Carefully pull the white and black wires out of the card using tweezers.
    • Remove the Wi-Fi card.
  4. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 4, 2 resimden 1. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 4, 2 resimden 2.
    • Unhook the two ribbon cables by using the iFixit opening tool to lift the black lock mechanisms up.
    • Slide the blue ribbon out of the lock mechanism.
    • Repeat these steps for both sides of each blue ribbon.
  5. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 5, 1 resimden 1.
    • Using your iFixit opening tool, slide the black lock mechanism toward the serial label.
    • Repeat the step on the opposite side of the cable.
    • Slide the blue cable out of the port using a pair of tweezers.
  6. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the touchpad cable by lifting the black lock mechanism up by using your iFixit opening tool.
    • Gently slide the cable out of its port.
  7. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 7, 1 resimden 1.
    • Use the iFixit opening tool to release both ends of the double male end of the speaker cable.
    • Disconnect the speaker cable from the port.
  8. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 8, 1 resimden 1.
    • Disconnect the black LCD cable directly above the hinges of the device by using an iFixit opening tool to lift up the black lock.
    • Slide the black LCD cable out of the connection port.
  9. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 9, 1 resimden 1.
    • Disconnect the black camera cable between the keyboard cable and the two blue ribbons which have been disconnected.
    • Using the tweezers, grab the wire end of the cable and carefully pull it away from the connection port.
    • Loosely place the disconnected cable away from the connection port.
  10. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 10, 3 resimden 1. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 10, 3 resimden 2. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement: adım 10, 3 resimden 3.
    • Flip the device over and open up the LCD screen.
    • Using the iFixit opening tool, gently place the tool in between the back-plate and the keyboard and lift up.
    • Slide the tool around the outside of the keyboard and lift up the tool while moving it around the boundary of the keyboard.
    • Be careful not to jam the tool deep into keyboard. This could cause damage to the motherboard.
    • Pull the keyboard away from the back-plate. Be careful the keyboard cable is not caught on the back-plate while performing this maneuver.
  11. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement, LCD Screen Assembly: adım 11, 3 resimden 1. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement, LCD Screen Assembly: adım 11, 3 resimden 2. Asus Chromebook C213SA-YS02 LCD Screen Assembly Replacement, LCD Screen Assembly: adım 11, 3 resimden 3.
    • Remove the two 4mm Phillips #00 stainless steel screws on one of the hinges.
    • Repeat the last step for the opposite hinge.
    • Carefully remove the LCD assembly off of the back plate. Be careful not to tug the LCD cable.
Sonuç
nathan
485 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G7, Saloman Fall 2019 UMass Dartmouth, Team S4-G7, Saloman Fall 2019 üyesi
UMASSD-SALOMAN-F19S4G7
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 12
Her zaman: 814
