Ana içeriğe geç
Asus Chromebook C300M USB Port Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300M USB Port Replacement, USB Port: adım 1, 2 resimden 1. Asus Chromebook C300M USB Port Replacement, USB Port: adım 1, 2 resimden 2.
    • Flip the chromebook on its front.
    • Remove the screws on the back using the Phillips #1 screwdriver.
    • Remove the six 8mm screws.
    • Remove the five 5mm screws.
  2. Asus Chromebook C300M USB Port Replacement: adım 2, 1 resimden 1.
    • Separate the plastic case from the keyboard at the seam using a plastic opening tool.
  3. Asus Chromebook C300M USB Port Replacement: adım 3, 2 resimden 1. Asus Chromebook C300M USB Port Replacement: adım 3, 2 resimden 2.
    • Fully separate the plastic case from the keyboard by lifting it upward.
  4. Asus Chromebook C300M USB Port Replacement: adım 4, 2 resimden 1. Asus Chromebook C300M USB Port Replacement: adım 4, 2 resimden 2.
    • The small and wide ribbon cables connect the keyboard to the motherboard.
    • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
    • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
  5. Asus Chromebook C300M USB Port Replacement: adım 5, 2 resimden 1. Asus Chromebook C300M USB Port Replacement: adım 5, 2 resimden 2.
    • Disconnect the USB port in the top right corner from the motherboard.
    • Unplug the the wide ribbon cable using spudger.
  6. Asus Chromebook C300M USB Port Replacement: adım 6, 2 resimden 1. Asus Chromebook C300M USB Port Replacement: adım 6, 2 resimden 2.
    • Remove the single 3mm screw on the left and bottom side of the USB Port using the Phillips #1 screwdriver.
    • Remove the three 5mm screws on the upper part of the USB port with the same screwdriver.
    • Lift the edge of the white casing. Remove the USB Port by pulling it toward the bottom of the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Rachel Cadle
259 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G2, Harley Spring 2019 IUPUI, Team S3-G2, Harley Spring 2019 üyesi
IUPUI-HARLEY-S19S3G2
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 741
