Ana içeriğe geç
Asus Chromebook C300MA DB01 Battery Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA DB01 Battery Replacement, Removing the Back Cover: adım 1, 1 resimden 1.
    • Remove the eight 9.0 mm Phillips screws along the perimeter of the case.
    • Remove the three 6.0 mm Phillips screws from the center of the case.
  2. Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: adım 2, 2 resimden 1. Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: adım 2, 2 resimden 2.
    • Slide the Jimmy in between the keyboard and underside of the laptop to remove the keyboard.
    • Leave the keyboard face down on the screen.
    • Do not pull the keyboard away from the laptop. The keyboard will still be attached with wires.
  3. Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: adım 3, 2 resimden 1. Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: adım 3, 2 resimden 2.
    • Use a nylon spudger to lift the latch on each wire jack and detach the keyboard wires.
    • After the tabs have been lifted, the wire can be gently pulled out by hand.
    • Set the keyboard aside.
  4. Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: adım 4, 3 resimden 1. Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: adım 4, 3 resimden 2. Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: adım 4, 3 resimden 3.
    • Remove the six 6.0mm Phillips screws on the battery.
    • Remove the wire jack from the battery. Use a nylon spudger to lift the latch.
    • Remove the battery from the device.
Sonuç
Earl Gill IV
193 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S10-G10, Wilson Spring 2019 IUPUI, Team S10-G10, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S10G10
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 216
