Ana içeriğe geç
Asus Chromebook C300MA DB01 Screen Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA DB01 Screen Replacement, Screen: adım 1, 3 resimden 1. Asus Chromebook C300MA DB01 Screen Replacement, Screen: adım 1, 3 resimden 2. Asus Chromebook C300MA DB01 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Use a Jimmy to pry off the hinge cover from the screen.
  2. Asus Chromebook C300MA DB01 Screen Replacement: adım 2, 2 resimden 1. Asus Chromebook C300MA DB01 Screen Replacement: adım 2, 2 resimden 2.
    • Run the Jimmy along the edges of the screen frame to unsnap it from the connectors.
    • Remove the screen frame manually.
  3. Asus Chromebook C300MA DB01 Screen Replacement: adım 3, 3 resimden 1. Asus Chromebook C300MA DB01 Screen Replacement: adım 3, 3 resimden 2. Asus Chromebook C300MA DB01 Screen Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the four screws on each corner of the screen.
    • Separate the screen from the top of the Chromebook with the Jimmy.
    • Avoid pulling the screen too far from the device as this can disconnect the wire located at the bottom of the screen.
    • Use the Jimmy to lift the latch on the wire jack.
    • Remove the wires and detach the screen from the device manually.
Sonuç
Earl Gill IV
193 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S10-G10, Wilson Spring 2019 IUPUI, Team S10-G10, Wilson Spring 2019 üyesi
IUPUI-WILSON-S19S10G10
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 116
