Ana içeriğe geç
Asus Chromebook C300MA-BBCLN12 Battery Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: adım 1, 2 resimden 1. Asus Chromebook C300MA-BBCLN12 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the eight 9.0mm Phillips #00 screws.
    • Remove the three 6.0mm Phillips #00 screws.
  2. Asus Chromebook C300MA-BBCLN12 Battery Replacement: adım 2, 3 resimden 1. Asus Chromebook C300MA-BBCLN12 Battery Replacement: adım 2, 3 resimden 2. Asus Chromebook C300MA-BBCLN12 Battery Replacement: adım 2, 3 resimden 3.
    • Separate the palm rest assembly from the bottom housing using the plastic opening tool.
    • It is recommended that you start from a corner and run the plastic opening tool along the edge of the housing.
    • Lift the palm rest assembly slowly to prevent damaging the two cables that connect it to the motherboard.
  3. Asus Chromebook C300MA-BBCLN12 Battery Replacement: adım 3, 3 resimden 1. Asus Chromebook C300MA-BBCLN12 Battery Replacement: adım 3, 3 resimden 2. Asus Chromebook C300MA-BBCLN12 Battery Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Flip back the hinges on the connectors that secure the wide black cable and the narrow white cable using the tweezers.
    • Disconnect the wide black cable from the motherboard by pulling the blue cable tab away from the connector.
    • Disconnect the white ribbon cable from the motherboard by pulling the blue cable tab away from the connector.
  4. Asus Chromebook C300MA-BBCLN12 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the six 6.0mm Phillips #00 screws that secure the battery to the bottom housing.
  5. Asus Chromebook C300MA-BBCLN12 Battery Replacement: adım 5, 2 resimden 1. Asus Chromebook C300MA-BBCLN12 Battery Replacement: adım 5, 2 resimden 2.
    • Disconnect the bundled cable connector that attaches the battery to the motherboard using the small plastic spudger.
  6. Asus Chromebook C300MA-BBCLN12 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the bottom housing.
Sonuç
Brooke Austin
419 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 440
