Ana içeriğe geç
Asus Chromebook C300MA-BBCLN12 Display Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: adım 1, 3 resimden 1. Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: adım 1, 3 resimden 2. Asus Chromebook C300MA-BBCLN12 Display Replacement, Display: adım 1, 3 resimden 3.
    • Wedge the tip of the plastic spudger between the outer display casing and the inner display panel liner.
    • Separate the outer display casing from the inner display panel by sliding the plastic spudger around the perimeter of the display.
    • It is necessary to pull the inner display panel firmly when separating it from the outer display casing along the bottom of the device.
  2. Asus Chromebook C300MA-BBCLN12 Display Replacement: adım 2, 3 resimden 1. Asus Chromebook C300MA-BBCLN12 Display Replacement: adım 2, 3 resimden 2. Asus Chromebook C300MA-BBCLN12 Display Replacement: adım 2, 3 resimden 3.
    • Remove the four 3.0mm PH00 screws from the four corners of the display.
    • Grip the edges of the display and tip it forward until it rests on the keyboard.
    • A cable connects the display to the display casing at the bottom. Separate the display panel slowly to prevent damaging the cable.
  3. Asus Chromebook C300MA-BBCLN12 Display Replacement: adım 3, 3 resimden 1. Asus Chromebook C300MA-BBCLN12 Display Replacement: adım 3, 3 resimden 2. Asus Chromebook C300MA-BBCLN12 Display Replacement: adım 3, 3 resimden 3.
    • Locate the gold cable connector that attaches the display to the bottom of the display housing.
    • Peel back the protective tape that covers the gold connector.
    • Disconnect the display from the display housing by gripping the sides of the gold display cable connector and pulling away from the bottom of the display.
Sonuç
Brooke Austin
419 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 236
