Ana içeriğe geç
Asus Chromebook C300MA-DB01 Battery Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA-DB01 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Battery Replacement: adım 3, 1 resimden 1.
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Battery Replacement: adım 4, 2 resimden 1. Asus Chromebook C300MA-DB01 Battery Replacement: adım 4, 2 resimden 2.
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Remove the six 6.0mm Philips screws, using the 64 bit driver from around the battery.
  6. Asus Chromebook C300MA-DB01 Battery Replacement: adım 6, 1 resimden 1.
    • Unplug the wire using the plastic opening tool that connects the battery with the board.
  7. Asus Chromebook C300MA-DB01 Battery Replacement: adım 7, 1 resimden 1.
    • Lift the battery out of the laptop
Sonuç
Bir başkası bu kılavuzu tamamladı.
wyatt boyatt
541 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G3, Eyestone Fall 2017 USF Tampa, Team S4-G3, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 2,254
