Ana içeriğe geç
Asus Chromebook C300MA-DB01 Mouse Pad Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA-DB01 Mouse Pad Replacement, Back Cover: adım 1, 1 resimden 1.
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: adım 2, 1 resimden 1.
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: adım 3, 1 resimden 1.
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: adım 4, 2 resimden 1. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: adım 4, 2 resimden 2.
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Mouse Pad Replacement, Mouse pad: adım 5, 1 resimden 1.
    • Use plastic opening tool to pry open clip holding keyboard wires to the circuit board.
    • Use plastic opening tool to pry open clip holding mouse pad wires to circuit board.
  6. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: adım 6, 2 resimden 1. Asus Chromebook C300MA-DB01 Mouse Pad Replacement: adım 6, 2 resimden 2.
    • Lift and remove keyboard from device. The keyboard and Mouse pad are one part that must be replaced simultaneously.
Sonuç
wyatt boyatt
541 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G3, Eyestone Fall 2017 USF Tampa, Team S4-G3, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 125
