Ana içeriğe geç
Asus Chromebook C300MA-DB01 Screen Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA-DB01 Screen Replacement, Screen: adım 1, 2 resimden 1. Asus Chromebook C300MA-DB01 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Use plastic opening tool to remove the frame around the screen. It is recommended to start in the upper corners.
  2. Asus Chromebook C300MA-DB01 Screen Replacement: adım 2, 2 resimden 1. Asus Chromebook C300MA-DB01 Screen Replacement: adım 2, 2 resimden 2.
    • Use plastic opening tool to remove plastic hinge casing located between the screen and keyboard.
  3. Asus Chromebook C300MA-DB01 Screen Replacement: adım 3, 1 resimden 1.
    • Use 64 bitdriver to remove 4 6.0 mm Phillips screws from screen the screws that need to be removed are located in the corners of the screen.
  4. Asus Chromebook C300MA-DB01 Screen Replacement: adım 4, 1 resimden 1.
    • Use plastic prying tool to detach the wire that connects the screen to the lower non-display half of the laptop.
  5. Asus Chromebook C300MA-DB01 Screen Replacement: adım 5, 1 resimden 1.
    • Lift and remove screen from the laptop.
Sonuç
wyatt boyatt
541 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S4-G3, Eyestone Fall 2017 USF Tampa, Team S4-G3, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S4G3
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 330
