Giriş
If you are having trouble with audio output on your device this guide can be useful. Be careful when unplugging wires as to not damage them.
Neye ihtiyacın var
Remove the six 6.0mm Philips screws, using the 64 bit driver from around the battery.
Use plastic opening tool to pry off the wire connecting the left side speaker to the circuit board.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Bonjour m. Merci pour la présentation. Pourriez-vous m'indiquer l'endroit où je peux me procurer des haut-parleurs pour un hp Omen 15 ? Merci d'avance. Email : dhujardaim@hotmail.com / dhujardaim@gmail.com
