Ana içeriğe geç
Asus Chromebook C300MA-DH02 Display Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: adım 1, 3 resimden 1. Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: adım 1, 3 resimden 2. Asus Chromebook C300MA-DH02 Display Replacement, Keyboard Panel: adım 1, 3 resimden 3.
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Display Replacement: adım 2, 1 resimden 1.
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Display Replacement: adım 3, 2 resimden 1. Asus Chromebook C300MA-DH02 Display Replacement: adım 3, 2 resimden 2.
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Display Replacement, Display: adım 4, 2 resimden 1. Asus Chromebook C300MA-DH02 Display Replacement, Display: adım 4, 2 resimden 2.
    • Remove the hinge protector by using the plastic opening tool to gently lift it up. It should come up easily.
  5. Asus Chromebook C300MA-DH02 Display Replacement: adım 5, 2 resimden 1. Asus Chromebook C300MA-DH02 Display Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool, separate the display cover bracket from the back of the display. Start from the top.
  6. Asus Chromebook C300MA-DH02 Display Replacement: adım 6, 2 resimden 1. Asus Chromebook C300MA-DH02 Display Replacement: adım 6, 2 resimden 2.
    • Remove the (4) four "4mm" screws in each corner that hold the display using the Phillips #000 screwdriver.
  7. Asus Chromebook C300MA-DH02 Display Replacement: adım 7, 1 resimden 1.
    • Lower the display to allow access to connector in back.
  8. Asus Chromebook C300MA-DH02 Display Replacement: adım 8, 2 resimden 1. Asus Chromebook C300MA-DH02 Display Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift the tape covering the connector with the tweezers.
    • Gently remove the display connector from the motherboard.
Sonuç
Zachary Leonard
304 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G4, Remmell Fall 2017 USF Tampa, Team S6-G4, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S6G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 236
