Ana içeriğe geç
Asus Chromebook C300MA-DH02 Motherboard Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: adım 1, 3 resimden 1. Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: adım 1, 3 resimden 2. Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: adım 1, 3 resimden 3.
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 2, 1 resimden 1.
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 3, 2 resimden 1. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 3, 2 resimden 2.
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Remove the 4 "4mm" screws on the silver motherboard cover with the Phillips #000 Screwdriver.
    • Remove the motherboard silver mount.
  5. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to remove the connection from sound driver on the bottom left of the motherboard.
  6. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 6, 1 resimden 1.
    • Gently remove the blue connector to the right side of the motherboard.
  7. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 7, 2 resimden 1. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 7, 2 resimden 2.
    • Use the Phillips #000 Screwdriver to remove the screw on right side of wireless card.
    • Remove the wireless card.
  8. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 8, 1 resimden 1.
    • Start by lifting tape up off of the connection. Remove the connection to display.
  9. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 9, 3 resimden 1. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 9, 3 resimden 2. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 9, 3 resimden 3.
    • Remove (3) three "4mm" screws that connect the hinge to the motherboard using the Phillips #000 Screwdriver.
    • Remove (5) five "4mm" screws around two sides of motherboard using the Phillips #000 Screwdriver.
  10. Asus Chromebook C300MA-DH02 Motherboard Replacement: adım 10, 1 resimden 1.
    • Gently remove motherboard from the Asus Chromebook.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Giang Le Nam Dang
149 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G4, Remmell Fall 2017 USF Tampa, Team S6-G4, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S6G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 261
