Giriş
The motherboard is the most important part of your devise. It is responsible of everything ranging from basic processing to complex programs.
Neye ihtiyacın var
Flip the Chromebook over so that the underside is facing up.
Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
Remove the 4 "4mm" screws on the silver motherboard cover with the Phillips #000 Screwdriver.
Remove the motherboard silver mount.
2 farklı kişi bu kılavuzu tamamladı.
