Ana içeriğe geç
Asus Chromebook C300MA-EDU Keyboard Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Asus Chromebook C300MA-EDU Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Keyboard Replacement: adım 2, 2 resimden 1. Asus Chromebook C300MA-EDU Keyboard Replacement: adım 2, 2 resimden 2.
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Keyboard Replacement: adım 3, 3 resimden 1. Asus Chromebook C300MA-EDU Keyboard Replacement: adım 3, 3 resimden 2. Asus Chromebook C300MA-EDU Keyboard Replacement: adım 3, 3 resimden 3.
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
Sonuç
Christopher Hart
501 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G3, Nance Fall 2017 USF Tampa, Team S2-G3, Nance Fall 2017 üyesi
USFT-NANCE-F17S2G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 671
