Ana içeriğe geç
Asus Chromebook C300MA-EDU LAN Card Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA-EDU LAN Card Replacement, Keyboard: adım 1, 2 resimden 1. Asus Chromebook C300MA-EDU LAN Card Replacement, Keyboard: adım 1, 2 resimden 2.
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 2, 2 resimden 1. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 2, 2 resimden 2.
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 3, 3 resimden 1. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 3, 3 resimden 2. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 3, 3 resimden 3.
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
  4. Asus Chromebook C300MA-EDU LAN Card Replacement, Battery: adım 4, 3 resimden 1. Asus Chromebook C300MA-EDU LAN Card Replacement, Battery: adım 4, 3 resimden 2. Asus Chromebook C300MA-EDU LAN Card Replacement, Battery: adım 4, 3 resimden 3.
    • Once the keyboard is removed, the battery is located on the bottom portion of the shell.
    • The battery is held in with six 6.5mm screws on opposing sides.
  5. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 5, 2 resimden 1. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 5, 2 resimden 2.
    • The battery is now held in with a tabbed connection to the CPU on the left side of the board. On the tabbed connection, there is a silver plate.
    • Gently push on the silver plate towards the screen until the plastic connection is free.
    • The tabbed connection should now slide out backwards.
  6. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 6, 2 resimden 1. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 6, 2 resimden 2.
    • At this point, using the plastic removal tool, lift the battery out of the shell.
  7. Asus Chromebook C300MA-EDU LAN Card Replacement, LAN Card: adım 7, 3 resimden 1. Asus Chromebook C300MA-EDU LAN Card Replacement, LAN Card: adım 7, 3 resimden 2. Asus Chromebook C300MA-EDU LAN Card Replacement, LAN Card: adım 7, 3 resimden 3.
    • Placing the Chromebook in the upright position, the LAN card is located on the upper right side of the shell.
    • The LAN card is pinned down with 2 coaxial connectors: main power and auxiliary input.
    • To disconnect, gently pull off the two connections using an upwards motion.
  8. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 8, 3 resimden 1. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 8, 3 resimden 2. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 8, 3 resimden 3.
    • On the right side of the LAN card is a 3.4mm Phillips head screw.
    • Using the J0 Phillips Head Tip from your tool kit, remove the screw, turning counter clockwise until the screw is free.
  9. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 9, 2 resimden 1. Asus Chromebook C300MA-EDU LAN Card Replacement: adım 9, 2 resimden 2.
    • At this point, the LAN card is only connected to the CPU.
    • To remove, gently slide out the LAN card from the CPU’s input clip.
    • The LAN card is now disconnected.
Sonuç
Christopher Hart
501 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G3, Nance Fall 2017 USF Tampa, Team S2-G3, Nance Fall 2017 üyesi
USFT-NANCE-F17S2G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 153
