Ana içeriğe geç
Asus Chromebook C300MA-EDU Thermal Paste Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300MA-EDU Thermal Paste Replacement, Keyboard: adım 1, 2 resimden 1. Asus Chromebook C300MA-EDU Thermal Paste Replacement, Keyboard: adım 1, 2 resimden 2.
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 2, 2 resimden 1. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 2, 2 resimden 2.
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 3, 3 resimden 1. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 3, 3 resimden 2. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 3, 3 resimden 3.
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
  4. Asus Chromebook C300MA-EDU Thermal Paste Replacement, Battery: adım 4, 3 resimden 1. Asus Chromebook C300MA-EDU Thermal Paste Replacement, Battery: adım 4, 3 resimden 2. Asus Chromebook C300MA-EDU Thermal Paste Replacement, Battery: adım 4, 3 resimden 3.
    • Once the keyboard is removed, the battery is located on the bottom portion of the shell.
    • The battery is held in with six 6.5mm screws on opposing sides.
  5. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 5, 2 resimden 1. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 5, 2 resimden 2.
    • The battery is now held in with a tabbed connection to the CPU on the left side of the board. On the tabbed connection, there is a silver plate.
    • Gently push on the silver plate towards the screen until the plastic connection is free.
    • The tabbed connection should now slide out backwards.
  6. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 6, 2 resimden 1. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 6, 2 resimden 2.
    • At this point, using the plastic removal tool, lift the battery out of the shell.
  7. Asus Chromebook C300MA-EDU Thermal Paste Replacement, Thermal Paste: adım 7, 3 resimden 1. Asus Chromebook C300MA-EDU Thermal Paste Replacement, Thermal Paste: adım 7, 3 resimden 2. Asus Chromebook C300MA-EDU Thermal Paste Replacement, Thermal Paste: adım 7, 3 resimden 3.
    • The metal plate is held in by two 3.4mm Phillip head screws.
    • Remove them by turning the screws counter clockwise.
    • Lift the plate off using a plastic opening tool or by hand.
  8. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 8, 3 resimden 1. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 8, 3 resimden 2. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 8, 3 resimden 3.
    • The existing thermal paste should now be exposed.
    • Using a paper towel, gently wipe off the existing thermal paste from both the CPU and the metal cover.
  9. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 9, 3 resimden 1. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 9, 3 resimden 2. Asus Chromebook C300MA-EDU Thermal Paste Replacement: adım 9, 3 resimden 3.
    • Once you remove the residue, apply a small amount of thermal paste in one area on the CPU.
    • The amount of thermal paste applied should be the size of a circle with a diameter of 2mm.
    • Applying too much thermal paste may result in the system not ventilating properly, leading to overheating issues.
    • Place metal plate back on. This will naturally spread the thermal paste across the CPU.
    • The thermal paste is now replaced.
Sonuç
Christopher Hart
501 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G3, Nance Fall 2017 USF Tampa, Team S2-G3, Nance Fall 2017 üyesi
USFT-NANCE-F17S2G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 15
Her zaman: 602
