Ana içeriğe geç
Asus Chromebook C300SA-DS02 LED Screen Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: adım 1, 2 resimden 1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: adım 1, 2 resimden 2.
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 2, 3 resimden 1. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 2, 3 resimden 2. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 2, 3 resimden 3.
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 3, 3 resimden 1. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 3, 3 resimden 2. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 3, 3 resimden 3.
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 4, 1 resimden 1.
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: adım 5, 2 resimden 1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 6, 2 resimden 1. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 6, 2 resimden 2.
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 7, 1 resimden 1.
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: adım 8, 2 resimden 1. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: adım 8, 2 resimden 2.
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 9, 1 resimden 1.
    • Peel back the tape covering the plug.
    • Slide the cable towards the screen and out of the input.
  10. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 10, 1 resimden 1.
    • Unscrew the 6 screws (5 millimeter) on the top right and left.
  11. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 11, 1 resimden 1.
    • Gently lift the screen up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 12, 1 resimden 1.
    • Pry off the face panel on the screen using the blue prying tool.
  13. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 13, 1 resimden 1.
    • Remove the four 2mm Phillips #0 screws from the four corners of the screen.
  14. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 14, 2 resimden 1. Asus Chromebook C300SA-DS02 LED Screen Replacement: adım 14, 2 resimden 2.
    • Gently lift screen
    • Peel back the adhesive covering the cable.
    • Remove the cable to free the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Celina Monteiro
224 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 UMass Dartmouth, Team S1-G7, Simcock Fall 2017 üyesi
UMASSD-SIMCOCK-F17S1G7
3 Üyeler
9 adet Kılavuz yazıldı
Bir Yorum
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
Glorybringers Child - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 702
