Ana içeriğe geç
Asus Chromebook C300SA-DS02 WiFi Card Replacement
Neye ihtiyacın var
  1. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Keyboard: adım 1, 2 resimden 1. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Keyboard: adım 1, 2 resimden 2.
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 2, 3 resimden 1. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 2, 3 resimden 2. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 2, 3 resimden 3.
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 3, 3 resimden 1. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 3, 3 resimden 2. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 3, 3 resimden 3.
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 4, 1 resimden 1.
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Battery: adım 5, 2 resimden 1. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 6, 2 resimden 1. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 6, 2 resimden 2.
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 7, 1 resimden 1.
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: adım 8, 3 resimden 1. Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: adım 8, 3 resimden 2. Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: adım 8, 3 resimden 3.
    • Use the spudger to pop the black and white coaxial WiFi cables up from the WiFi card.
  9. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 9, 2 resimden 1. Asus Chromebook C300SA-DS02 WiFi Card Replacement: adım 9, 2 resimden 2.
    • Remove the one 3.6mm Phillips #0 screw from the WiFi card.
    • Pull and lift the WiFi card away from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sarah Westberg
22.969 İtibar
70 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.718 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 411
