Ana içeriğe geç
Asus Chromebook C523N Back Cover Replacement
Neye ihtiyacın var
  1. Asus Chromebook C523N Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Asus Chromebook C523N Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Back Cover Replacement: adım 2, 2 resimden 1. Asus Chromebook C523N Back Cover Replacement: adım 2, 2 resimden 2.
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Back Cover Replacement: adım 3, 2 resimden 1. Asus Chromebook C523N Back Cover Replacement: adım 3, 2 resimden 2.
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 41
Her zaman: 3,008
